Rear bearings, Has any tried this?? |
736conver |
Jan 21 2006, 07:44 PM
Advanced Member Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None |
Ok instead of installing the bearing into the trailing arm first what about installing it onto the hub first. Maybe someone has already done this, but I did it tonight and it worked really slick.
I used my 12 ton press and pressed the bearing onto the hub, went on really smooth and sqaure. Now if your going to do this you need to put on you bearing retaining plates onto the hub first. I then took the hub with bearing installed and inserted it into the trailing arm. Now with the hub and bearing plate on it seem to go straight in, no problems. And I dont have any play in the hub. Maybe I just got lucky but out of the 4 or 5 bearings I have done this was by far the easiest and I didnt ruin any bearings trying to install them. Maybe others have done the same??? Sorry no pictures. |
Lo-Fi Version | Time is now: 12th June 2024 - 09:08 AM |
