> Can't shift into 4th gear., ¿#&@$%!
Air_Cooled_Nut
post Jan 23 2006, 07:15 PM
914 Ronin - 914 owner who lost his 914club.com
Ok, I've been adjusting the shifter in the cabin per the various shop manuals. Currently, I can get every gear except 4th. Even the slightest of changes doesn't seem to work. If I take slightly larger adjustments, my shifting becomes R-1-2-3 or 2-3-4-5. So, yes, 4th is possible and I was able to use 4th for a couple of months prior to this sudden blockage (for lack of a better word). It's as if a rubber bumper was placed in front of the shifter where the 4th gear position should be.
Now, this car is of questionable past and shows signs of neglect. 1-2 gears need to be eased into otherwise they grind. I do have a rebuilt tranny that I kept from my last teener but I really don't want to install it unless I really have to i.e. the failure is in the original tranny. She's still driveable, it would just be nice to have use of 4th gear.
When I dropped the engine/tranny to fix the oil leaks and clean everything, then put it back into the car, I installed new shifter bushings and cone screws, and liberally greased everything. Could it be that I put the engine in slightly askew? Suggestions/help please.
Joe Ricard
post Jan 23 2006, 08:41 PM
CUMONIWANNARACEU
I was thinking more of an interference within the tunnel like the seat belt bolt.
But then again if you can get R123 or 2345 then you have a bad set of plastic bushings in the coupler (forward part of the aft shift rod as it goes through the fire wall) where the front cone screw is.
When my coupler took a dump that was exactly my symptom.
- Lo-Fi Version Time is now: 11th July 2025 - 12:02 PM
