bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
Revised with more clear subject line....
I just need to know if indeed the TS2 sensors (head temp) are in fact close to a 13mm size, rather than the larger size I thought I noticed in my 2.0 from my old engine. anywho, I looked at the pelican order sheet and it shows it fitting ALL Years except 73 2.0, which used the ballast resistor. are they close to 13mm, or not? Oh and do i need to buy a deep socket and cut a slot into it so I can pass the wire through, or is there a better way? b Attached image(s) ![]() |
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,413 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
Before you grind up your tools, see if you can coil the wire up and fit it inside a deep socket. Or run the wire through the socket and use small vise grips to turn it. Otherwise grind a hole in the socket or grind a corner off of an extension. |
Lo-Fi Version | Time is now: 2nd July 2025 - 09:37 PM |
