> Cylinder Head Temp Sensor Size, is there only one size?
bd1308
post Jan 25 2006, 01:28 PM
Sir Post-a-lot
Revised with more clear subject line....
I just need to know if indeed the TS2 sensors (head temp) are in fact close to a 13mm size, rather than the larger size I thought I noticed in my 2.0 from my old engine.
anywho, I looked at the pelican order sheet and it shows it fitting ALL Years except 73 2.0, which used the ballast resistor.
are they close to 13mm, or not? Oh and do i need to buy a deep socket and cut a slot into it so I can pass the wire through, or is there a better way?
b
Dave_Darling
post Jan 25 2006, 07:58 PM
914 Idiot
Knock the corner off of an extension, that seems to be the easiest route. The square part that plugs into the back of the socket--grind just enough of one corner off so that the wire fits between the extension and the socket.
--DD
bd1308   Cylinder Head Temp Sensor Size   Jan 25 2006, 01:28 PM
type47   do you want wrench size/socket size to remove CHT?...   Jan 25 2006, 01:47 PM
bd1308   thx. b   Jan 25 2006, 01:52 PM
Rand     Jan 25 2006, 01:54 PM
d7n7master   I did this not 2 long ago. Drill size = 9.8mm Tap ...   Jan 25 2006, 01:58 PM
bd1308
  Jan 26 2006, 01:03 AM
bd1308     Jan 26 2006, 12:24 PM
- Lo-Fi Version Time is now: 3rd July 2025 - 02:32 AM
