> Cylinder Head Temp Sensor Size, is there only one size?
bd1308
post Jan 25 2006, 01:28 PM
Sir Post-a-lot
Revised with more clear subject line....
I just need to know if indeed the TS2 sensors (head temp) are in fact close to a 13mm size, rather than the larger size I thought I noticed in my 2.0 from my old engine.
anywho, I looked at the pelican order sheet and it shows it fitting ALL Years except 73 2.0, which used the ballast resistor.
are they close to 13mm, or not? Oh and do i need to buy a deep socket and cut a slot into it so I can pass the wire through, or is there a better way?
b
bd1308
post Jan 26 2006, 06:17 AM
Sir Post-a-lot
QUOTE (Cap'n Krusty @ Jan 25 2006, 09:13 PM)
Glad you got it fixed! However, it's REALLY DEPRESSING to see SO MUCH bad information passed on for what should be a simple answer. If you're not sure people, LOOK IT UP before you give advice. This stuff is archived, and that's where people come up with real problems. The wrench size is 13 mm, always has been. There is NO other size for the CHT sensor on ANY 914, T4, T3, T2, or T1 motor. Yes, there are TWO different CHT sensors for 914s. However, they can be interchanged, as this signal is used only until the engine's warmed up. As Dave said, it's easier (and better) to cut the corner off an extension than the socket. Infringing on the structural integrity of the socket can result in it damaging the wrench flats of the sensor if it's really tight. Cutting the wire is bullshit, adding another possible signal failure point. Hope you installed the copper washer, it seals the threads and aids conductivity. Hope you got the CHT sensor good and tight as well, because that ground is REALLY important. The Cap'n, as Krusty as I wanna be!
mine was a silver color, not copper.
It came in the bag (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
b
bd1308   Cylinder Head Temp Sensor Size   Jan 25 2006, 01:28 PM
type47   do you want wrench size/socket size to remove CHT?...   Jan 25 2006, 01:47 PM
bd1308   thx. b   Jan 25 2006, 01:52 PM
Rand     Jan 25 2006, 01:54 PM
d7n7master   I did this not 2 long ago. Drill size = 9.8mm Tap ...   Jan 25 2006, 01:58 PM
Dave_Darling   Knock the corner off of an extension, that seems t...   Jan 25 2006, 07:58 PM
bd1308
  Jan 26 2006, 01:03 AM
bd1308     Jan 26 2006, 12:24 PM
- Lo-Fi Version Time is now: 2nd July 2025 - 10:19 PM
