> Using a Vanagon Distributor, for megasquirt
yarin
post Jan 26 2006, 10:17 AM
'14-X'in FOOL
I got an interesting response on the megasquirt forums regarding ignition triggering. I was planning on locking my stock dizzy and installing a pertronix hall sensor unit in there. Has anyone tried this?
Score a distributor from a late model Vanagon with Digifant (NOT the one with the vacuum can). It has:
1) Hall sensor
2) Locked down timing
3) Drops in to the engine
Cheap from a junkyard, and you can probably sell the stock distributor on e(vil)Bay and turn a net profit.
R2.0
Mueller
post Jan 26 2006, 11:10 AM
914 Freak!
interesting idea, are you going to run megaspark that uses a CDI box?
your MS will have to control spark timing, the dizzy will just distribute the spark....
i'd avoid the pertronix, a hall circuit can be built for less than $10 and installed in your dizzy or on the fan if you that route.
yarin   Using a Vanagon Distributor   Jan 26 2006, 10:17 AM
Mueller   interesting idea, are you going to run megaspark t...   Jan 26 2006, 11:10 AM
DNHunt   When MSII gets 2nd wheel support, I'm planning...   Jan 26 2006, 11:31 AM
yarin   I'm in the process of building MS II V.3.0. It...   Jan 26 2006, 12:04 PM
Cap'n Krusty   87-91 Vanagon distributors would be fine, but the ...   Jan 26 2006, 12:12 PM
kwales   I'm gonna correct the Cap'n That's 86...   Jan 26 2006, 01:34 PM
lapuwali   The Vanagon distributor would relieve you of the n...   Jan 26 2006, 01:38 PM
alpha434   Bushings wear out. End up having to put replacemen...   Jan 26 2006, 01:40 PM
kwales   There aint nuttin in a Vanagon distributor,,,,, O...   Jan 26 2006, 02:15 PM
Cap'n Krusty   Soorrrrrry. 86 to 91 is correct. Brain fart...   Jan 26 2006, 02:50 PM
yarin   Does anyone have pics or a procedure to lock and a...   Jan 26 2006, 03:17 PM
alpha434   Yeah! You had better apologize for being off a...   Jan 26 2006, 03:21 PM
lapuwali   I don't know of any crank fire systems that ar...   Jan 26 2006, 03:52 PM
alpha434   What- no one's thought to use a po'dunk pl...   Jan 26 2006, 04:07 PM
lapuwali   ...   Jan 26 2006, 04:16 PM
alpha434   Optical makes no contact. Thats why. Absolutly no ...   Jan 26 2006, 04:37 PM
lapuwali   VR and Hall also make no contact. VR = variable r...   Jan 26 2006, 04:42 PM
yarin   ...   Jan 26 2006, 08:06 PM
alpha434   Oh. Yeah. I've taken care of that. Mwhahaha...   Jan 26 2006, 08:12 PM
Mueller   ...   Jan 26 2006, 08:19 PM
R2.0     Jan 27 2006, 10:17 PM
DNHunt   Hey R2.0, here's what I did. I takes the place...   Jan 27 2006, 10:47 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 09:43 AM
