| Rand |
Jan 28 2006, 04:50 PM
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,414 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Somebody school me on formula 1 tires... why the tall sidewalls? In street tires, the more extreme, the lower the profile. Shorter sidewalls, less flex, more cornering traction... Seems like in anything except F1, the tires are very low profile.
| lapuwali |
Jan 29 2006, 12:01 AM
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
I wouldn't remove ALL restrictions.
My F1 rulebook would include all of the current safety regulations for the cars, which have been very successful at ensuring driver's survive terrible shunts. I would, however, completely drop all rules governing everything else, including engine size limits. Physics will take care of limiting power, by limiting available traction. You can make way too much power simply by using a large, slow-turning engine, which would be vastly cheaper than a 19,000rpm 3.0 V10. Better tires will come along, but I suspect we're close to physical limits now. Remember that slicks first came into being as an answer to the huge power from 3.0 F1 engines, and they were a great leap forward in tire technology, which hadn't progressed all that much in the prior decade. Make pitstops impractical by limiting stops to 2 crewmen, so even a 1 tire change will take some time, and ban adding fuel during a pitstop. This limits traction by simply requiring tires last the race, but also allows tire changes during the race in case of punctures or flat-spotting. By forcing teams to start the race with 100% of the fuel they need, you indirectly limit power, and encourage efficiency. Fewer crewman also means smaller and cheaper teams, and a safer pitline. However, doing all of this could easily produce cars that are nearly undrivable by humans (they pull 4G now, and CART's experiences at Texas World Speedway a few years ago suggest that 6G is a practical upper limit). You may end up with an even worse situation than now wrt to passing. And you still get into the situation where one well-heeled team destroys everyone else. The last nearly unlimited series was Can-Am, which was eventually dominated by the Porsche 917-30 (all 1500 turbocharged hp), and everyone else packed up and went home. |
Rand OT: Formula 1 tire profile Jan 28 2006, 04:50 PM
dinomium trying to keep the racing competitve with grooves ... Jan 28 2006, 04:52 PM
r_towle lower sidewall, less flex, therefore less grip.
L... Jan 28 2006, 04:57 PM
dlo914 hmm...good question. after some thinking i remembe... Jan 28 2006, 05:00 PM
Aaron Cox Jan 28 2006, 05:03 PM
Rand I almost mentioned "except drag cars" in my origin... Jan 28 2006, 05:09 PM
messix http://www.914world.... Jan 28 2006, 05:28 PM
alpha434 Isn't the tire restriction standard for all fo... Jan 28 2006, 07:22 PM
dinomium Fomula1.com
It the offical FIA site so of course i... Jan 28 2006, 07:28 PM
lapuwali The tires have tall sidewalls because the rules di... Jan 28 2006, 08:53 PM
J P Stein James:
These discussions are no fun when someone t... Jan 28 2006, 09:36 PM
alpha434 ... Jan 28 2006, 10:04 PM
Elliot Cannon The only limits I would like to see is horse power... Jan 28 2006, 11:09 PM
Jeroen F1 tires have a fairly stiff sidewall (unlike drag... Jan 28 2006, 11:18 PM
Rand Makes me wonder what F1 cars could do if all restr... Jan 28 2006, 11:24 PM
Rand I shouldn't have said ALL restrictions. I was ... Jan 29 2006, 12:24 AM
dinomium I think that if you remove some of the rediculous ... Jan 29 2006, 12:44 AM
alpha434 Jan 29 2006, 01:20 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:40 PM |
