How to deal with transmission oil leak., It's slow now, will it get worse ? |
scoobie |
Jan 30 2006, 05:32 PM
Newbie Group: Members Posts: 3 Joined: 4-January 06 From: Torrance, CA Member No.: 5,364 |
Hi folks, newbie to this forum, so if I inadvertently commit bad netiquette please give me some slack.
I have a 1972 1.7, I've noticed drops of oil on my driveway ever since I got the car 4 and 1/2 years ago, it's coming from the rear near the gear that drives the speedometer (so I am told, I'm not a 914 expert). I've recently changed the transmission oil (as I started noticing a whine in 4th gear and I suspect its due to the gear oil leak) and the tech told me I had only 1 quart of oil in there, where normally there should be 6 quarts. So, my conclusion is that it leaked about 5 quarts in about 11000 miles (I filled the gear oil when I first got the car, and have driven 11000 miles since). My questions are: am I correct in my assumption about the leakage, and if so, can I get away with not fixing it (at the present time) and just do the occasional gear oil service. Am I doing anything detrimental to the transmission or other parts of the car ? Thanks for your inputs. |
scoobie |
Jan 31 2006, 01:00 AM
You folks make it sound sooooo easy :-) Ok, let's say I've manage to locate the keeper nut, and have the 13 mm wrench. Do I have to drain the gear oil first before I attempt to loosen the nut (otherwise wouldn't the gear oil spurt all over my face) ? If I need to drain the oil first, what is the recommended procedure ?
I'm sorry if this line of questions seem juvenile, the most challenging mechanical task I've done on this car is changing the motor oil. |
Lo-Fi Version | Time is now: 10th June 2024 - 08:11 AM |
