> Head vent ports, needed?
yarin
post Feb 6 2006, 10:07 AM
'14-X'in FOOL
While pulling my carbs off I noticed that each head has an air vent. One was capped off, the other was open.
Where should these go and why are they needed? Will capping these contribute to oil leaks?
Here is a pic I found: http://www.914world.com/bbs2/uploads/blog-1...-1131214564.jpg
Thanks
Jake Raby
post Feb 6 2006, 11:19 AM
Engine Surgeon
engines that can't breathe don't have all their power freed up AND they leak oil. The pressure will find a way out!
I have a 4Qt stainless steel tank in the works, it'll be VERY nice and slim to fit nicely..
yarin   Head vent ports   Feb 6 2006, 10:07 AM
ClayPerrine   You need the head vents to keep from building exce...   Feb 6 2006, 10:11 AM
yarin   Yea i figured that. There is no vent box on my car...   Feb 6 2006, 10:28 AM
Cap'n Krusty     Feb 6 2006, 10:34 AM
Jake Raby   engines that can't breathe don't have all ...   Feb 6 2006, 11:19 AM
Headrage   My '75 2.0 w/d-jet didn't have them but I ...   Feb 6 2006, 11:23 AM
yarin   ...   Feb 6 2006, 11:49 AM
SirAndy     Feb 6 2006, 11:49 AM
yarin   Is there a breather on that? Filter? What's th...   Feb 6 2006, 01:16 PM
Aaron Cox   they have a metal perforated screen, then a foam e...   Feb 6 2006, 01:25 PM
Rand   There seem to be some mixed signals about which ca...   Feb 6 2006, 01:43 PM
yarin   I found a few: JC Whitney http://www.jcwhitney.co...   Feb 6 2006, 02:00 PM
Aaron Cox   your supposed to mount it high enuff where it will...   Feb 6 2006, 02:01 PM
SirAndy     Feb 6 2006, 04:45 PM
Marty Yeoman     Feb 6 2006, 07:27 PM
dmenche914   Basically the crank case vent vents the case, and ...   Feb 6 2006, 08:16 PM
Marty Yeoman     Feb 7 2006, 12:02 PM
yarin   Just ordered the one from CB performance with a fe...   Feb 7 2006, 12:22 PM
dmenche914   Oil on the meter vane seems like good enough reaso...   Feb 7 2006, 12:30 PM
Brando   http://www.914world.com/bbs2/ht...   Feb 8 2006, 02:35 PM
914efi   I was thinking that if you hooked the vent up to t...   Feb 8 2006, 02:57 PM
dmenche914   If I read that the way you meant, hooking up the a...   Feb 8 2006, 03:29 PM
Mueller   on my old L-Jet, I machined Delrin plugs to fill u...   Feb 8 2006, 03:35 PM
dmenche914   So Mikes car with l-jet ought to be able to run ju...   Feb 8 2006, 03:58 PM
Mueller
- Lo-Fi Version Time is now: 2nd April 2026 - 11:03 AM
