richardL |
Senior Member ![]() ![]() ![]() Group: Members Posts: 713 Joined: 27-January 03 From: San Diego, CA Member No.: 201 Region Association: None ![]() |
I'm hoping someone here has an answer to this, its driving me crazy.
I have a client using an ODBC connection (on XP Pro), to connect to a SQL Server database. Its set to use NT authentication. You can create the ODBC Datasource, select the appropriate database on the appropriate server and test the connection - all is fine. However, when you check it is actually connected to the another database on that Server, apparently the one defined as the defualt for that server. For instance I created a connection pointing at the standard Northwind database, then I opened Access, linked to an ODBC datasource, selected my new datasource and instead of being offered a list of the tables in Northwind, I was offered a list of the tables in the other default database (not master). I eventually got it to work as I expected, by logging off of the domain account and doing a login as the adminstrator for the local machine. In that account, the DSN worked as expected. I have never seen a DSN with NT authentication simply provide access to another database - it should tell me I don't have access rights to the database selected or whatever. In this case the default database is the clients main live production system, so it appears to be a glaring security risk. Anybody know why this might happen, or even how to make it happen/stop? Thanks. |
Lo-Fi Version | Time is now: 17th July 2025 - 04:28 AM |
