| yarin |
Feb 6 2006, 10:07 AM
'14-X'in FOOL ![]() ![]() ![]() Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
While pulling my carbs off I noticed that each head has an air vent. One was capped off, the other was open.
Where should these go and why are they needed? Will capping these contribute to oil leaks? Here is a pic I found: http://www.914world.com/bbs2/uploads/blog-1...-1131214564.jpg Thanks |
| MartyYeoman |
Feb 6 2006, 08:37 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,546 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California
Clay, Please explain further. I'm thinking of installing vents but don't want to open a 'can of worms" being L-jet and all. Any info would be appreciated. Thanks |
yarin Head vent ports Feb 6 2006, 10:07 AM
ClayPerrine You need the head vents to keep from building exce... Feb 6 2006, 10:11 AM
yarin Yea i figured that. There is no vent box on my car... Feb 6 2006, 10:28 AM
Cap'n Krusty Feb 6 2006, 10:34 AM
Jake Raby engines that can't breathe don't have all ... Feb 6 2006, 11:19 AM
Headrage My '75 2.0 w/d-jet didn't have them but I ... Feb 6 2006, 11:23 AM
yarin ... Feb 6 2006, 11:49 AM
SirAndy Feb 6 2006, 11:49 AM
yarin Is there a breather on that? Filter? What's th... Feb 6 2006, 01:16 PM
Aaron Cox they have a metal perforated screen, then a foam e... Feb 6 2006, 01:25 PM
Rand There seem to be some mixed signals about which ca... Feb 6 2006, 01:43 PM
yarin I found a few:
JC Whitney http://www.jcwhitney.co... Feb 6 2006, 02:00 PM
Aaron Cox your supposed to mount it high enuff where it will... Feb 6 2006, 02:01 PM
SirAndy Feb 6 2006, 04:45 PM
Marty Yeoman Feb 6 2006, 07:27 PM
dmenche914 Basically the crank case vent vents the case, and ... Feb 6 2006, 08:16 PM
Marty Yeoman Feb 7 2006, 12:02 PM
yarin Just ordered the one from CB performance with a fe... Feb 7 2006, 12:22 PM
dmenche914 Oil on the meter vane seems like good enough reaso... Feb 7 2006, 12:30 PM
Brando http://www.914world.com/bbs2/ht... Feb 8 2006, 02:35 PM
914efi I was thinking that if you hooked the vent up to t... Feb 8 2006, 02:57 PM
dmenche914 If I read that the way you meant, hooking up the a... Feb 8 2006, 03:29 PM
Mueller on my old L-Jet, I machined Delrin plugs to fill u... Feb 8 2006, 03:35 PM
dmenche914 So Mikes car with l-jet ought to be able to run ju... Feb 8 2006, 03:58 PM
Mueller ![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:25 AM |
