Oil Strainer Cover Q |
richardL |
Feb 6 2006, 06:10 PM
Senior Member Group: Members Posts: 713 Joined: 27-January 03 From: San Diego, CA Member No.: 201 Region Association: None |
I removed the cover under the engine for the oil strainer, cleaned out all the gunk and put it back on, tightened it carefully to the torque setting specified and now it is leaking.
There was no gasket under the cover - is that correct? How do you make a good tight seal, since you can't simply tighten it right up I believe? Richard |
eg914 |
Feb 7 2006, 12:19 AM
Member Group: Members Posts: 319 Joined: 17-June 04 From: Elk Grove, CA Member No.: 2,223 Region Association: None |
I have seen gasket sets with thin and with thick gaskets. Is there any difference? Seems the thinner are easier to cut with the sump plate. Leaks real good then.
Lo-Fi Version | Time is now: 12th June 2024 - 04:23 AM |
