| yarin |
Feb 6 2006, 10:07 AM
'14-X'in FOOL ![]() ![]() ![]() Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
While pulling my carbs off I noticed that each head has an air vent. One was capped off, the other was open.
Where should these go and why are they needed? Will capping these contribute to oil leaks? Here is a pic I found: http://www.914world.com/bbs2/uploads/blog-1...-1131214564.jpg Thanks |
| dmenche914 |
Feb 7 2006, 12:30 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 |
Oil on the meter vane seems like good enough reason for the factory to add the vent down stream of the vane. Extra oil shouldn't hurt the carb operation. It how my VW's and 356 is set up (factroy set up). My 356 has some valve guide blowby, so the carb does get oily, but it tunes and works just like the other carb that is clean (no vent line on other side carb.)
Guess what it comes down to is how much false air can the L-jet handle before problems in drivability and running, and how much false air extra would be added by head vents. If head vents were tied into the same line as the case vent, ventalation would decrease over individual hoses, however the ventilation will still be more than a single case vent, and certainly be more even (ie head would recieve direct venting now, verse via the push rod tubes) Over all vent flow would be restricted by going to a single port on the intake manifold, so that should minimize false air, yet still benifit from head venting (with a corresponding decrease in case venting flow) The junction where the hose meet up would be the restirction, down to one hose diameter. same as stock. Additional restriction can be added to the hose to balance the total "false air" flow to the same as that as the stock L jet would see, just is now the same false air flow is from three sources, not just the case. you could "tune " the restriction with an oxygen sensor to measure and match stock mixture level at the tail pipe (assuming all other engine system are in order). Make any sense??? |
yarin Head vent ports Feb 6 2006, 10:07 AM
ClayPerrine You need the head vents to keep from building exce... Feb 6 2006, 10:11 AM
yarin Yea i figured that. There is no vent box on my car... Feb 6 2006, 10:28 AM
Cap'n Krusty Feb 6 2006, 10:34 AM
Jake Raby engines that can't breathe don't have all ... Feb 6 2006, 11:19 AM
Headrage My '75 2.0 w/d-jet didn't have them but I ... Feb 6 2006, 11:23 AM
yarin ... Feb 6 2006, 11:49 AM
SirAndy Feb 6 2006, 11:49 AM
yarin Is there a breather on that? Filter? What's th... Feb 6 2006, 01:16 PM
Aaron Cox they have a metal perforated screen, then a foam e... Feb 6 2006, 01:25 PM
Rand There seem to be some mixed signals about which ca... Feb 6 2006, 01:43 PM
yarin I found a few:
JC Whitney http://www.jcwhitney.co... Feb 6 2006, 02:00 PM
Aaron Cox your supposed to mount it high enuff where it will... Feb 6 2006, 02:01 PM
SirAndy Feb 6 2006, 04:45 PM
Marty Yeoman Feb 6 2006, 07:27 PM
dmenche914 Basically the crank case vent vents the case, and ... Feb 6 2006, 08:16 PM
Marty Yeoman Feb 7 2006, 12:02 PM
yarin Just ordered the one from CB performance with a fe... Feb 7 2006, 12:22 PM
Brando http://www.914world.com/bbs2/ht... Feb 8 2006, 02:35 PM
914efi I was thinking that if you hooked the vent up to t... Feb 8 2006, 02:57 PM
dmenche914 If I read that the way you meant, hooking up the a... Feb 8 2006, 03:29 PM
Mueller on my old L-Jet, I machined Delrin plugs to fill u... Feb 8 2006, 03:35 PM
dmenche914 So Mikes car with l-jet ought to be able to run ju... Feb 8 2006, 03:58 PM
Mueller ![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:25 AM |
