| DNHunt |
Feb 8 2006, 11:26 AM
914 Wizard? No way. I got too much to learn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
I've almost finished tuning my engine with MS. It's one of Jake's 2270 kits and it has a fairly aggressive cam with lift just shy of .500" on the exhaust and intake with plenty of duration and overlap. The valves are 44 X 36 and there is some slight porting. At any rate it will pump a great deal more air than a stock engine.
The only mods I have made to my intake system are rebore of the throttle body to 50mm from the stock 45mm and a K&N air filter in the stock air box. There has always been a question about the limits of the stock intake system on a modified engine. I think I can say I'm convinced that it will support my engine without trouble with the rebored throttle body. The proof is in the logs I have been recording and which can be seen on the graph below. This represents acceleration through the first 3 gears with 3rd at WOT. The boxes at the lower left show RPM's at 6400, the manifold pressure is 94 kpa and the throttle position is 100% (WOT). Atmospheric pressure that day was 97 kpa so the engine drops 3 kpa through the air filter. The purple line in the yellow circle tells the story. It stays at a consistent 94 kpa from the time I open the throttle after shifting into 3rd at ~ 4000 RPM until I shift into 4th at 6400 RPM. If the intake could not supply enough air that purple line would fall indicating the engine is trying to suck more air. For anyone considering fuel injecting a larger than stock engine don't rule out the stock intake until you prove it will not work. Boring the throttle body is an easy thing for a machinist (cheap too) to do. The hardest part of the whole thing is making a new throttle plate to fit the bigger bore and that didn't take more than an afternoon. Attached image(s)
| Joe Ricard |
Feb 8 2006, 11:57 AM
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Wow Dave tha's really cool.
I am so glad you finally got that motor running as you wanted it. Perfection is quite hard to attain huh? But it looks like you did it. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) |
DNHunt Stock 2.0l plenum and runners on 2270 Feb 8 2006, 11:26 AM
DNHunt Here's a little closer look at the proof
Dave Feb 8 2006, 11:30 AM
Krieger914 Cool work. You can go bigger on the throttle body... Feb 8 2006, 11:46 AM
72914S Feb 8 2006, 12:07 PM
72914S I am working,this is running in the back ground.IS... Feb 8 2006, 12:12 PM
rhodyguy ah dave...you did mod the long tapering intake tub... Feb 8 2006, 12:21 PM
Jeff Nelson Dave, was the snout on the airbox modified? Feb 8 2006, 01:16 PM
rhodyguy yes. he did change it.
k Feb 8 2006, 01:19 PM
anthony Is it proven that the stock throttle body is a res... Feb 8 2006, 02:08 PM
Krieger914 Sorry to take so long to respond. I've been t... Feb 11 2006, 04:50 PM
Mueller ![]() ![]() |
Lo-Fi Version | Time is now: 9th November 2026 - 11:38 AM |
