| Korijo |
Sep 5 2003, 03:32 AM
[]D o [] o []V[] o []D ![]() ![]() ![]() Group: Members Posts: 1,308 Joined: 16-July 03 From: North Bend, WA Member No.: 914 |
I searched, but no luck.
Bought a 1 1/16" hole saw (all my old ones are worn out), but it seems too small next to the Tarret bar. What size do I need ?? |
| Jeroen |
Sep 5 2003, 05:37 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
Hey Jeff,
Yep, get a new inner reinforcement plate You need to grind a small pice of sheetmetal out of the way (out of the boxed part underneath the plate, which is shown in your first pic) Also weld then new plate to the chassis Check the thread on Jenny's car, it shows a couple of pics of the inner plate installed cheers, Jeroen |
Korijo No holes for sway bar... Sep 5 2003, 03:32 AM
Racer Chris 1 1/16 is close to 27mm which would be big enough ... Sep 5 2003, 05:42 AM
Ira Ramin Dave,
The bar OD is 1”, which will be pretty tig... Sep 5 2003, 07:17 AM
Qarl :o Are there instructions? My Smart Racing bar ha... Sep 5 2003, 07:20 AM
Bruce Allert Hey there Dave, I just installed a stock sway a fe... Sep 5 2003, 07:25 AM
Korijo I dont have any existing holes, so I cant go the d... Sep 5 2003, 01:00 PM
ChrisReale Davre, If I remember correctly, the tarett bar is ... Sep 5 2003, 01:30 PM
DNHunt Hey my hearing has finally cleared up. When's ... Sep 5 2003, 02:01 PM
Korijo Dave,
I think Chris and Kevin are coming next wee... Sep 5 2003, 02:35 PM
Jeroen Dave,
Tarett bar needs a 1.125" hole saw
(got the... Sep 5 2003, 05:16 PM
Jeffs9146 I hope you don't mind but I am going to tag on... Sep 5 2003, 05:27 PM
Jeffs9146 #2 Sep 5 2003, 05:28 PM
Jeffs9146 #03 Sep 5 2003, 05:29 PM
Korijo Jeff,
Looks like someone didn't notch the she... Sep 5 2003, 05:38 PM
Jeffs9146
Bruce Allert Was talking to a guy at our last AX about just ins... Sep 5 2003, 07:04 PM
Jeffs9146
Brad Roberts Jeff... weld a nut back on the plate. Its not a bi... Sep 8 2003, 10:20 AM
Brad Roberts Wait.. I dont get it.. (and your pics dont show it... Sep 8 2003, 10:22 AM
Jeffs9146 They cut the bottom of the plate off! So it ha... Sep 8 2003, 10:25 AM
Brad Roberts My welding looks like crap.. but the plate looked ... Sep 8 2003, 10:39 AM
Jeffs9146 Yes, I cant find it either! I remember seeing ... Sep 8 2003, 10:45 AM
Jeroen Here is another pic (showing the same) that Andy j... Sep 8 2003, 11:23 AM
Jeffs9146 That one doesn't look welded in! Can I get... Sep 8 2003, 11:33 AM
Brad Roberts I welded Jenny's because it was a stock bar an... Sep 8 2003, 11:44 AM
Jeffs9146 So welding is not nessary??
Jeff Sep 8 2003, 12:16 PM
Brad Roberts Not if you have the back plate like what you have.... Sep 8 2003, 12:19 PM
Bruce Allert Well ain't that sumpin!!! I actual... Sep 8 2003, 01:56 PM
-P- I just did mine this weekend. Lots of fun with the... Sep 8 2003, 03:46 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 03:23 AM |
