> 914-6 Conversion Shift Linkage Question, Straight or Bent? Let the opinions fly
John
post Feb 13 2006, 11:45 AM
member? what's a member?
I am about to fabricate some rear shift linkages for some -6 conversions, and have been seeing a slight bend in the rear shift rod.
When I did the conversion 13+ years ago, it was common(?) for the shift rod to be absolutely straight as is confirmed by my existing shift rod. We purchased the straight rod from a vendor in CA 13 or 14 years ago possibly from Galen Bieker and it has worked well for both the original 901 side-shifter as well as the current 915 (vellios) transmission.
My main questions are:
1. Is there a need for the shift rod to have a slight bend?
2. Does the slight bend help minimize binding in the bushings?
3. Is the bend to avoid bumping into the bottom of the engine case?
4. What is the location of the slight bend(s)?
5. Is there 2 slight bends or is there just one?
Pics would be very helpful.
Otherwise, I'll continue to make up straight ones and verify that they work with my existing 914-6 conversion.
Thanks for your input.
Trekkor
post Feb 13 2006, 12:28 PM
I do things...
If you are referring to the Patrick mount, that's what I use.
I believe the "Quick Six" is offered by Motor Miester and I haven't seen that one.
KT
JOHNMAN   914-6 Conversion Shift Linkage Question   Feb 13 2006, 11:45 AM
john rogers   When I did my conversion I had to put a slight ben...   Feb 13 2006, 11:58 AM
trekkor   Back when I did mine, the first thing I noticed is...   Feb 13 2006, 12:05 PM
Mueller   I thought it was the motor mount that also had a b...   Feb 13 2006, 12:05 PM
trekkor   The motor mount is directly above the shift linkag...   Feb 13 2006, 12:12 PM
Mueller   <...   Feb 13 2006, 12:14 PM
trekkor   If you are referring to the Patrick mount, that...   Feb 13 2006, 12:28 PM
JOHNMAN   KT, Which headers are you using?   Feb 13 2006, 12:43 PM
trekkor   MSDS headers. Martin Schneider, MSDS, inc http:/...   Feb 13 2006, 12:54 PM
brant   Trekkor, taking the bend out as much as possible...   Feb 13 2006, 02:33 PM
trekkor   Nearly all 914's use a shift rod this bent. I ...   Feb 13 2006, 05:05 PM
brant   The original -6 rod is not bent... and some say it...   Feb 13 2006, 05:14 PM
736conver   No scientific data here, but I made my shift rod s...   Feb 13 2006, 05:22 PM
JOHNMAN   So I have a couple for straight (me and 736conver)...   Feb 13 2006, 11:28 PM
RON S.   John, I made mine straight,it seemed the sim...   Feb 14 2006, 06:15 AM
RON S.   #2 center section   Feb 14 2006, 06:19 AM
RON S.   Last one, Tail section, Ron   Feb 14 2006, 06:24 AM
9146986   I've been making conversion shift rods for the...   Feb 14 2006, 07:00 AM
Dr Evil   I had mine bent by Dan Root because it was recomme...   Feb 14 2006, 11:38 AM
JOHNMAN   I started out and made a jig from an original shif...   Feb 14 2006, 01:05 PM
9146986   OK, OK! Since I don't have the original m...   Feb 14 2006, 01:47 PM
dimitri   Looking at my original 914-6 and the 74 6 conversi...   Feb 15 2006, 03:16 PM
porschetub   My shifter rod had a bend around 150 mm from the e...   Oct 31 2016, 12:03 AM
gereed75   I believe it is straight but optimally will need a...   Oct 31 2016, 06:42 AM
gandalf_025   I know you are talking side shifter.. but here is ...   Oct 31 2016, 01:47 PM
SirAndy   Holy thread necromancer! :blink: Also, wha...   Oct 31 2016, 01:51 PM
jim912928   I didn't have to modify mine at all. 75 914, ...   Oct 31 2016, 02:38 PM
porschetub   I didn't have to modify mine at all. 75 914,...   Nov 1 2016, 07:36 PM
horizontally-opposed   Have a 73 side-shift car with a 2.2 six. John Ho...   Oct 31 2016, 03:28 PM
altitude411   Holy thread necromancer! :blink: :shades2...   Oct 31 2016, 04:29 PM
jim912928   stock bend...non-modified from my 75...shifts perf...   Nov 1 2016, 08:53 PM
Mark Henry   My rod is straight...but I did a Marky do copy roo...   Nov 1 2016, 09:40 PM
mb911   I don't remember modding my last 6 conversion....   Nov 2 2016, 05:00 AM
mlindner   I'm still working on my conversion and this ha...   Nov 2 2016, 07:47 AM
rgalla9146   This is what I did. It's an assembly of fo...   Nov 10 2016, 09:14 AM
- Lo-Fi Version Time is now: 15th April 2026 - 10:43 AM
