| seanery |
Sep 6 2003, 05:01 PM
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,857 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
This looks interesting (melts at 720 degrees F) so not a super high temp fix, but quick and it looked fairly strong.
Here is their webpage Any thoughts, opinions, experiences? |
| Katmanken |
Sep 7 2003, 08:51 AM
You haven't seen me if anybody asks... ![]() ![]() ![]() ![]() Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
The Sears product is a "Self Fluxing Aluminum Rod " 1/8 " diameter and is made(repackaged?) by US Forge. I believe it was less than $10.00 for 12 or so rods.
Very little info on the package and none on how to use. Claims that the material can be used "to wearface aluminum" "good color match for aluminum" and "low working temperature." Also, "the flux is in the rod". Worked great for my application. Only problem is it flows vey freely when hot and I had trouble building up a thick section. Then again, I'm not the worlds greatest welder. Web research claims it isn't a solder and you need to crimp the end of partially used rods to save the flux. I'd use it again. (IMG:style_emoticons/default/smile.gif) |
seanery Anyone seen or used Alumaloy? Sep 6 2003, 05:01 PM
elmonte As seen on TV not a good sign. Too good to be true... Sep 6 2003, 05:17 PM
ChrisReale I'be used a similar product with ok results. ... Sep 6 2003, 05:57 PM
kwales Seanery,
Sounds like the aluminum weld rod I boug... Sep 6 2003, 07:37 PM
kwales Oh yeah, that propane torch wouldn't have cut ... Sep 6 2003, 07:41 PM
mskala A few years ago a friend and I split a $45 ba... Sep 6 2003, 08:48 PM
rick 918-S I bought a similar product at Northern tools. I at... Sep 7 2003, 12:23 AM
Racer Chris It's probably the same stuff I buy at the loca... Sep 7 2003, 08:17 AM
John Kelly I think that stuff is actually for aluminum brazin... Sep 7 2003, 10:25 AM
seanery yeah, I think you're right john. Sep 7 2003, 10:28 AM
Lawrence Pot metal?
Could this stuff be used to fix broken... Sep 7 2003, 07:40 PM
Racer Chris <... Sep 7 2003, 09:20 PM
Aaron Cox ![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 03:23 AM |
