> Need Ignition Help, Wet engine won't start
bwilless
post Sep 7 2003, 04:36 PM
I washed my motor yesterday at the car wash and the car has not run since. I was careful to keep the low pressure spray away from the carbs and distributor, but somthing bad happened. I've done this before with no problems at all.
First the car would not even turn over, just a clunk noise. After about 10 minutes it started turning over, but I had no spark. My engine is a stock 2.0/4 with pertronics and MSD 6AL.
I figured I must have gotten inside the distributor wet, so I towed the car home and left the distributor cap off over night. Here in Tempe AZ the air is dry, it should have dryed up fast. Well this moring the car still would not fire. I tried replacing the MSD and Coil with units a friend just bought, but I had the same problem. I verified the wiring on the MSD verified that I had 12v on the heavy Red wire, ground on the heavy black wire, and power on the small red wire when the ignition is turned on.
I'm not sure what to do next. I've never messed with the insides of the distributor, and I'm not sure what could have gone wrong.
I'm puzzeled why the car did not turn over at first, thats why I took the time to check voltages at the MSD.
Any ideas on what to look at? (IMG:style_emoticons/default/sad.gif)
bwilless
post Sep 7 2003, 05:10 PM
The relay box is covered. There was moisture in the cap. What does a fried rotor or cap look like? I have an old cap that I can try.
Thanks,
Brian
- Lo-Fi Version Time is now: 9th June 2026 - 02:30 AM
