brake selection, would this work Eric or DaveP? |
DanT |
Feb 17 2006, 12:29 AM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
I know in the past everyone has discussed using M calipers on the front with stock 914-4 rears along with a T fitting in place of proportioning valve.
What if you were to use the M calipers and 914-4 fronts on the rear utilizing the proportioning valve. would this negate enough of the rear bias with the larger 914-4 front pistons to give good braking? Possibly utilizing a milder rear pad as well with a very aggressive front pad? What do you think....and no I don't care about the E brake. (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) Thanks |
Eric_Shea |
Feb 17 2006, 10:40 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
I think you're spot on then (this is for racing?). Here would be my choices. I think I'd go 'A' or 'B' and keep a handbrake (I know, you don't care about it). System A: 911 M-Strut with vented rotors (or Mueller hub if you're 4-lug) M-Caliper Porterfields T-Fitting Stock Rear on a Solid rotor Porterfields System B: 911 M-Strut with vented rotors (or Mueller hub if you're 4-lug) M-Caliper Porterfields T-Fitting V-Caliper Rear with Vented rotor Porterfields System C: 911 M-Strut with vented rotors (or Mueller hub if you're 4-lug) M-Caliper Porterfields T-Fitting Cockpit adjustable Valve Front 914 Rear on a Solid rotor Porterfields |
Lo-Fi Version | Time is now: 1st June 2024 - 09:22 PM |
