sk8kat1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 911 Joined: 10-October 05 From: belvidere ,IL Member No.: 4,937 ![]() |
I right now have the19 mm MC , SS brake lines and bmw front caliper upgrade from PO
I have heard the the stockers are just as good if working properly .. is this true ... is there a better setup than both and keeping the 4 lug .. |
DanT |
Going back to the Dark Side! ![]() ![]() ![]() ![]() Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None ![]() |
The billet hubs are the only way you can run the SC vented rotors.
The hubs mimic the function and look of 911 hubs. This way you can buy just rotors instead of your current rotor/hub combination. With the billet hubs you don't have to buy change bearings etc when you need new rotors. Otherwise what would be the point of putting a larger caliper and generating more heat with no improved way of dissipating that heat? Why add M calipers and keep solid rotors. What is your obsession with thinking that the hubs are something comical? |
