| siverson |
Sep 8 2003, 01:12 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,464 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California
Well, on June 5th I thought I'd be done by 9/14:
http://www.914world.com/bbs2/index.php?act...521&hl=siverson but it I won't quite make it... but I'm close! I got the engine in this past weekend, and most of the hard work is behind me. 2-3 weeks and it will be drivable (I just work on it as time permits on the weekends), and by the end of the year I'll have the interior and everything done (whole project will have been almost 5 years at that point...) First, some update pictures, and then I've got some random questions. The project: The garage is quite small, but it makes me keep things organized (things AREN'T organized in this picture): (IMG:http://www.streamload.com/steve/914_update_9-7-2003_-_small/small_garage_big_project.jpg) Going in: (IMG:http://www.streamload.com/steve/914_update_9-7-2003_-_small/engine_going_in.jpg) It's in! (IMG:http://www.streamload.com/steve/914_update_9-7-2003_-_small/engine_in_bottom.jpg) View through the window. Not to debate the merits have having an access panel, but... what about making this hole even larger (round?) and getting some strong clear plexiglass to cover it? I know it's probably a bad idea due to fires/etc (i.e. "fire"wall), so please someone talk me out of that idea: I'm thinking 914/Modena-esque... (IMG:http://www.streamload.com/steve/914_update_9-7-2003_-_small/firewall_fan.jpg) Front blower area (what a pain to assemble, but it looks nice now. Most everything was replated, and with nice hoses (w/ clamps) the defroster seems to really blow very strong! (IMG:http://www.streamload.com/steve/914_update_9-7-2003_-_small/front_trunk_defroster.jpg) Oil cooler installed: (IMG:http://www.streamload.com/steve/914_update_9-7-2003_-_small/front_trunk.jpg) Question: I'm using an '84 914 w/ the Vellious kit and I believe that this is called a pull clutch. Does anyone have any pictures as to what these parts look like when in a 911? I played around a bit and lined things up like this (below) but really have no idea if this is correct. Any body familiar with this type of clutch? How do I assemble all these levers? Where does the clutch cable typically attach? (IMG:http://www.streamload.com/steve/914_update_9-7-2003_-_small/clutch1.jpg) (IMG:http://www.streamload.com/steve/914_update_9-7-2003_-_small/clutch2.jpg) (IMG:http://www.streamload.com/steve/914_update_9-7-2003_-_small/clutch3.jpg) Question: I bought two new stricker plates that we're advertised as LH or RH for 73 or later (car is a 74), but they both appear to be passenger side. What gives? Does this part really work on either side? It seems like the left and right must be different... (I noticed it's also printed in Tweeks catalog as LH or RH) (IMG:http://www.streamload.com/steve/914_update_9-7-2003_-_small/drivers_side_stricker_plate.jpg) I'm still struggling with exactly how to route the brake lines for my non-standard setup (993TT front, C2T rear, 23mm master cylinder, central brake bias): It is a -very- tight fit to get hard line into the rear calipers (front is fine using a banjo fitting). Should I take a large hammer to the trailing arm and make room? A banjo fitting won't even fit. Should I be concerned? See pictures of slightly "kinked" line: (IMG:http://www.streamload.com/steve/914_update_9-7-2003_-_small/rear_brake1.jpg) (IMG:http://www.streamload.com/steve/914_update_9-7-2003_-_small/rear_brake2.jpg) (IMG:http://www.streamload.com/steve/914_update_9-7-2003_-_small/rear_brake3.jpg) (IMG:http://www.streamload.com/steve/914_update_9-7-2003_-_small/rear_brake4.jpg) Question: Does any one have pictures of cars plumbed with braided lines for the brakes? I'd like to see how they secured the brake lines to the chassis (and around the front struts, etc). Thanks for any tips or ideas! -Steve |
| Brad Roberts |
Sep 8 2003, 01:43 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Man it looks good. I remember seeing it for the first time at Glenn's place way back.. It has come a long way. That is ORANGE.
Is that oil cooler big enough ?? What about a fan on it for traffic situations ?? ala factory 964/993 Now lets see if I can shed some light on some of your questions.. 1. Cover with clear plexiglass. I think it's a great idea (also make the hole bigger) 2. Clutch cable attaches to the small "hook" you see. let me dig up a pic of the part you need... BTW.. we convert them to a single short arm without all the return spring BS. 3. You have the wrong striker plate. They sent you two "rights". 4. That brake line fitting scares the living SHIT out of me. You need a banjo fitting with that line going straight into it. Not that 95 degree angle you currently have. 5. There is NO clean way to get the lines to the struts or the control arms. Most I have seen are zip tied to them. B |
siverson 914-6 progess and more random questions Sep 8 2003, 01:12 AM
siverson Thanks for the info.
> Is that oil cooler big eno... Sep 8 2003, 01:54 AM
ChrisReale Your car looks fantastic. I cannot help with your... Sep 8 2003, 01:55 AM
Brad Roberts Just real quick.. while I'm still awake.. You ... Sep 8 2003, 02:17 AM
Brad Roberts Wait.. here is a better shot showing ALL the arms ... Sep 8 2003, 02:20 AM
Brad Roberts see how #5 is straight ?
see how # 7 has a slight... Sep 8 2003, 02:21 AM
redshift WoW! The primer looks fantastic! :o What c... Sep 8 2003, 02:24 AM
Brad Roberts Steve stands at least 6'5 if I recall correctl... Sep 8 2003, 02:27 AM
redshift lol
M Sep 8 2003, 02:29 AM
Justin Fischer <... Sep 8 2003, 07:15 AM
rhodyguy beautiful car, great work.
kevin Sep 8 2003, 07:31 AM
Bleyseng Love that Orange!!! :trophy:
Why not... Sep 8 2003, 08:40 AM
siverson Brad, thanks for the pictures. Those arm arms look... Sep 8 2003, 10:09 AM
Brad Roberts Steve.. number 5 will do it (and 8).. I noticed yo... Sep 8 2003, 10:16 AM
silver six <... Sep 8 2003, 12:38 PM
silver six dddd Sep 8 2003, 12:38 PM
fiid Dude,
That car looks awesome.
I would make the a... Sep 8 2003, 01:17 PM
siverson Yeah, I'm not so sure about the plexiglas, but... Sep 8 2003, 03:47 PM
scotty Ah! I'm blind!
Nice... :headbanger: Sep 8 2003, 09:32 PM
Eric Taylor wow i'm speechless. It's like my dream bei... Sep 8 2003, 09:47 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 03:24 AM |
