strut & shock question for the racers ... |
SirAndy |
Feb 19 2006, 04:21 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
i got a mid '80s carrera frontend with the black struts, so i'm assuming i've got the stock 911 boge shocks.
the car is lowered quite a bit and i was hitting the 3-piece rubber stops frequently. i was told i could safely cut the rubber stop down to 2 pieces, which i did and it helped quite a bit, adding more shock travel. but i still bottom out occasionally on a larger bump etc. so, my question is, for the boge shocks, can i safely remove a second piece from the rubber stop and run a one piece stop only ??? (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) Andy |
SirAndy |
Feb 20 2006, 02:38 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) so, what if i: - jack up the car, unload the suspension completely, move the rubber spacer all the way up on the rod, then measure the distance from the top of the shock to the bottom of the rubber. that'll be my current effective shock travel. - then, i remove the shock, i push the rod all the way down, mark it, then extend it all the way out. that will give me the largest "possible" shock travel. - the difference between the two should tell me how much of the rubber spacer i can cut off, if any ... anyone see any flaws in this? (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) Andy |
Lo-Fi Version | Time is now: 8th June 2024 - 11:28 PM |
