strut & shock question for the racers ... |
SirAndy |
Feb 19 2006, 04:21 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
i got a mid '80s carrera frontend with the black struts, so i'm assuming i've got the stock 911 boge shocks.
the car is lowered quite a bit and i was hitting the 3-piece rubber stops frequently. i was told i could safely cut the rubber stop down to 2 pieces, which i did and it helped quite a bit, adding more shock travel. but i still bottom out occasionally on a larger bump etc. so, my question is, for the boge shocks, can i safely remove a second piece from the rubber stop and run a one piece stop only ??? (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) Andy |
ChrisFoley |
Feb 20 2006, 04:18 PM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Kevin, The disks are intended to be used in a stack, not just one at a time. If you stack enough of them it will certainly stop the shock from bottoming internally. I also understand that it is desirable to have a rising rate by using a rubber snubber instead of a sudden increase by hitting the limit all at once. (btw, my front shocks are monotube (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) ) |
Lo-Fi Version | Time is now: 8th June 2024 - 10:05 PM |
