| 914zim |
Sep 7 2003, 09:17 PM
Still pretty clueless... ![]() ![]() Group: Members Posts: 221 Joined: 29-July 03 From: New Berlin, WI Member No.: 962 |
Hey guys:
While draining the old brake fluid in my 914 (it's been sitting for 4 years), I noticed someone had put a label on the fluid reservior that reads "SILICONE FLUID ONLY" So, I assume a PO had put silicone brake fluid in the system. After I've rebuilt the calipers and replaced the pads, I will be putting regular DOT 4 Heavy Duty brake fluid in. This is the stuff I got from the local parts supply store. I drained the old fluid about 2 days ago and it's been sitting empty since. So, my question is: So I need to do anything special like flush the system with anything (alchohol?) before I put the new DOT 4 fluid in when I bleed the system? Thanks in advance for any help! Andy... |
| Air_Cooled_Nut |
Sep 8 2003, 11:11 AM
914 Ronin - 914 owner who lost his 914club.com ![]() ![]() ![]() Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
Well, DOT 5 will NOT hurt your paint but it's not biodegradable.
914zim Silcone brake fluid Sep 7 2003, 09:17 PM
Brad Roberts Just keep bleeding them with the new fluid and flu... Sep 7 2003, 11:59 PM
Air_Cooled_Nut Curious, why don't you continue to use the DOT... Sep 8 2003, 11:05 AM
seanery which one is less caustic?
that's the one i... Sep 8 2003, 11:09 AM
HarveyH It's been eight or ten years since I used sili... Sep 8 2003, 11:22 AM
Lawrence Am I behind the times and the only one still using... Sep 8 2003, 01:39 PM
Air_Cooled_Nut It does have a higher boiling point. I don't ... Sep 8 2003, 11:08 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 02:29 AM |
