> Silcone brake fluid, I'm changing back to DOT 4
914zim
post Sep 7 2003, 09:17 PM
Still pretty clueless...
Hey guys:
While draining the old brake fluid in my 914 (it's been sitting for 4 years), I noticed someone had put a label on the fluid reservior that reads "SILICONE FLUID ONLY"
So, I assume a PO had put silicone brake fluid in the system.
After I've rebuilt the calipers and replaced the pads, I will be putting regular DOT 4 Heavy Duty brake fluid in. This is the stuff I got from the local parts supply store.
I drained the old fluid about 2 days ago and it's been sitting empty since.
So, my question is:
So I need to do anything special like flush the system with anything (alchohol?) before I put the new DOT 4 fluid in when I bleed the system?
Thanks in advance for any help!
Andy...
HarveyH
post Sep 8 2003, 11:22 AM
It's been eight or ten years since I used silicone fluid, and they may have changed it, but back then, it was significantly more compressible than glycol based brake fluid.
Good points: doesn't absorb water, so little or no corrosion in the system, and I think a higher boiling point.
Bad points: longer brake pedal travel, softer brakes.
Harvey
- Lo-Fi Version Time is now: 9th June 2026 - 02:29 AM
