sk8kat1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 911 Joined: 10-October 05 From: belvidere ,IL Member No.: 4,937 ![]() |
I right now have the19 mm MC , SS brake lines and bmw front caliper upgrade from PO
I have heard the the stockers are just as good if working properly .. is this true ... is there a better setup than both and keeping the 4 lug .. |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
If that doesn't throw you through the windshield... you've got a problem.
Probably... hard to beat factory rubber for your application. If you plan on ripping everything off/out then you may want to look into it at that time. Check them while you're down there. If they're excessively worn it should be done. Not sure about those shocks. They may be Boge's Some Boge inserts I've had were orange... Orange usually means Koni but I don't think they're "Hecho en Mexico" |
