Trans and or german expert needed, Factory manual clarification!!! |
bondo |
Feb 20 2006, 08:33 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
On page 5.1-5/3 of the factory manual, bottom right, it says: "NOTE The values are always rounded off to the next 0.05 mm."
My adjusting dimension is 63.35mm, and after adding .3mm of gasket the measurement comes out to 63.32. Do they mean I should always round UP to the next .05mm (63.35), or do they mean I should round to the NEAREST .05mm (63.30)? I suspect that this clarity issue comes from a translation from german.. but maybe not. I can only add or subtract gaskets in .05mm increments, so I can either leave it at 63.32mm or I can make it 63.37mm. What do I do? |
bondo |
Feb 21 2006, 08:15 PM
Sigh.. Spec is .005 - .007 inch backlash.. With the shims I have and with fudging between the two options of pinion depth I can use, the closes I can get is .002" and .010". What's worse, too little or too much?
Lo-Fi Version | Time is now: 12th June 2024 - 10:25 AM |
