| ModPR3 |
Feb 21 2006, 08:59 PM
Member ![]() ![]() Group: Members Posts: 96 Joined: 7-February 06 From: Orange County, CA Member No.: 5,544 |
ok this is for the subie powered guys. i think im going to go with the subaru engine and renegade hybrids conversion kit but dont know which engine to use. i want something reliable and daily drivable not looking for crazy power, probably a max of 250hp turbo powered or 180hp n/a powered. so what do i use. a 2.5 n/a motor or 2.0t turbo motor. i would perfer to use the turbo motor but will go n/a if i have to. if i go with the turbo motor, about how much and who can make a turbo header/manifold and exhust for me that will not require cutting the origional 914 sheetmetal. also if i go with the turbo motor do i have enough room to run a heater system. thanks for the help.
| Mueller |
Feb 21 2006, 09:16 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
if using the Renegade kit, your smart choice is to ask "them" which motor to use since that'll dictate whether or not the kit and the engine you pick is compatible (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
turbo motors generally cost more up front and are a little harder to tune...how much work can you do yourself? |
ModPR3 subaru engine choice Feb 21 2006, 08:59 PM
Porcharu Feb 21 2006, 09:33 PM
ModPR3 ... Feb 21 2006, 09:39 PM
ModPR3 <... Feb 21 2006, 09:47 PM
Porcharu Feb 21 2006, 11:12 PM
mrdezyne I ended up going with the N/A 2.5 for simplicity s... Feb 22 2006, 11:20 AM
Crazyhippy If you are going to go through the trouble of doin... Feb 22 2006, 01:26 PM
Hydra I went with an N/A 2.0l dohc engine (ej20), it... Feb 23 2006, 06:33 AM
soloracer Another subie choice would be the 3.3 flat six out... Feb 23 2006, 10:22 AM
brer the four cam 2.5 is known for its head sealing pro... Feb 23 2006, 11:01 AM
WRX914 <... Feb 25 2006, 04:43 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:03 AM |
