davesprinkle |
Senior Member ![]() ![]() ![]() Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None ![]() ![]() |
I've got a set of very weathered Pedrinis on my 14. Setting aside, for now, the obvious way to improve their appearance (5-lug conversion, duh), can I get any suggestions on refinishing?
Powdercoat -- cheap (~$75/wheel), durable, attractive, but there is some speculation that the baking process might affect the strength of the alloy Paint -- probably the best way to duplicate the factory finish, but surprisingly expensive (~$150/wheel), and of dubious durability Polish -- don't know about expense (maybe the same as powdercoat?), looks good initially, but requires continual attention Thoughts, vendors, other options? Thanks in advance. |
davesprinkle |
Maybe I should have clarified that the $150 quote was given to me by Wheel Enhancement. I understand that a DIY approach would be significantly less expensive. But since you mentioned bead-blasting, what vendor do you use for your bead-blasting? |
Lo-Fi Version | Time is now: 9th July 2025 - 04:22 PM |
