> what are the symptoms of a, bad coil and a bad condensor ??
jimkelly
post Feb 27 2006, 01:54 PM
Delaware USA
Thanks
r_towle
post Feb 27 2006, 04:35 PM
Custom Member
Coil test is bye eye...I am aure there is a meter out there somewhere....
Basically take a sparkplug and connect a plug wire to it...hold the plug against ground so the body of the plug is well grounded...
Watch the color of the spark...you are looking for a bright strong spark between blue and white...a yellow spark is a weak spark.
Condensor either works or does not work...
You can test the condensor by using a test light...
You are looking for the light to light up the negative side of the coil when the point open. If that happens, your condensor works.
Points cost 3-4 per set...get a few spares...I change at least twice a year.
Rich
- Lo-Fi Version Time is now: 9th July 2025 - 04:30 PM
