Adjusting Distributor Vacuum advance retard, How do you do it? |
porsche735 |
Sep 9 2003, 10:01 PM
Member Group: Members Posts: 189 Joined: 10-January 03 From: Los Altos, CA Member No.: 127 |
So, we seem to have found the source of our blown pistons and ring lands! Our distributor (off a fresh rebuild I might add), does not have enough vacuum retard at WOT. Turns out we were way too far advanced (about 38-40 degrees) under load.
My question is, how do you adjust the vacuum unit? The advance and retard work when you pull a vacuum on them. However, I suspect that the adjustment screw is not adjusted properly. It is almost all the way out. Does anyone know how to get this speced right? Thanks for your help, Chris |
Bleyseng |
Sep 9 2003, 10:37 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Both my dizzys have the adjustable vacuum canister too. Like I said you don' t need to run the vacuum advance or even the retard. I have plugged the retard hose and only use the vacuum advance as it seems runs alittle better this way. The retard is for emmisions I thought. Just use the mechanical advance to set up the engine for now. Someone will chime in on how to adjust the advance.
Geoff |
Lo-Fi Version | Time is now: 10th June 2024 - 06:10 PM |
