Adjusting Distributor Vacuum advance retard, How do you do it? |
porsche735 |
Sep 9 2003, 10:01 PM
Member Group: Members Posts: 189 Joined: 10-January 03 From: Los Altos, CA Member No.: 127 |
So, we seem to have found the source of our blown pistons and ring lands! Our distributor (off a fresh rebuild I might add), does not have enough vacuum retard at WOT. Turns out we were way too far advanced (about 38-40 degrees) under load.
My question is, how do you adjust the vacuum unit? The advance and retard work when you pull a vacuum on them. However, I suspect that the adjustment screw is not adjusted properly. It is almost all the way out. Does anyone know how to get this speced right? Thanks for your help, Chris |
porsche735 |
Sep 9 2003, 11:04 PM
We can turn it into a "How many threads are you showing?" thread....
Lo-Fi Version | Time is now: 10th June 2024 - 07:19 PM |
