| John |
Mar 4 2006, 09:36 AM
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
Has anyone rewired a later model car to that of an early model car to get individual turn signal indiators?
The early style was wired so that each indicator light (in the tach) had one of the turn signal wires (black/white stripe or black/green stripe) and the blue/white stripe. As far as I can tell, the flasher relay is the same, but the wiring is different due to the fact that the 1974 and later cars only had the single indicator light in the tach. The 74 wiring diagram shows the indicator light wired to the blue/white stripe and ground. Is this rihgt or not. maybe I'll wire it up and find out..... |
bd1308 http://www.914world.com/bbs2... Mar 4 2006, 09:45 AM
Bartlett 914 I have a 75. I was able to do what you wanted. If ... Mar 4 2006, 02:45 PM
jk76.914 I figured this out. Do you guys still need to kno... Jul 6 2006, 12:44 AM
double-a i did this. not hard, just need to run a new wire ... Jul 6 2006, 08:07 AM
BigDBass :popcorn:
I would like to know the secret. Jul 6 2006, 11:27 AM
914MF :boing: :boing: Yes, please tell us. :help: :not... Jul 6 2006, 12:11 PM
jim_hoyland I seen a late model with the turn signal indicator... Jul 6 2006, 01:24 PM
jim_hoyland :popcorn: ... Jul 6 2006, 03:53 PM
jk76.914 Hi Folks, well I'm back at it. I will go thro... Jul 6 2006, 10:45 PM
jk76.914 All right. Back again. Here's the schematic ... Jul 6 2006, 11:35 PM
bd1308 :)
thx Jul 6 2006, 11:51 PM
JOHNMAN I found the answer several months ago in UpFixin v... Jul 7 2006, 12:30 AM
BigDBass Thanks for the excellent description. Jul 7 2006, 06:53 AM
Lawrence I nominate this thread for Classic Status!
Ch... Jul 7 2006, 08:51 AM
tdgray 2nd :thumbsup:
Very good write up. Very detaile... Jul 7 2006, 11:41 AM
jim_hoyland Good description; would you mind adding a few word... Jul 10 2006, 09:07 PM
JOHNMAN Jim,
You would add two wires from the emergency f... Jul 11 2006, 01:13 AM
jk76.914
That's right. I didn't want to pull out ... Jul 11 2006, 08:28 AM
jim_hoyland Thanks for the installation detail--makes sense to... Jul 11 2006, 08:47 AM
jim_hoyland One last question; do the repeater lights ground t... Jul 11 2006, 09:39 PM
jk76.914 That's right. Just like the front and rear si... Jul 12 2006, 07:18 AM
jim_hoyland The Saabs sound good; would you have the part numb... Jul 12 2006, 11:18 AM
nivekdodge Wow someone else had to do this Aug 6 2022, 10:06 AM![]() ![]() |
Lo-Fi Version | Time is now: 25th October 2026 - 01:20 PM |
