| mightyohm |
Jul 30 2004, 12:29 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,279 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest |
Hey guys, I need some help with a release fork/pivot shim issue I have run into.
I am working on reinstalling my transmission after my lost driveshaft incident. I have a new clutch release fork that I installed, and I noticed that when I stuck the transmission back on the engine, the fork doesn't have more than a few mm of free play before it hits the transmission housing. So I think hmmm and I pull it back apart. Then I think back to the last time I did this, I put in a new cup in the old throwout arm. At that time I noticed the ball cup stuck way out of the fork and I had to actually trim it down to fit. I thought it was weird but blamed Brad on giving me crap parts (just kidding Brad). I even took a picture, shown below. Attached image(s)
| bondo |
Mar 4 2006, 08:50 PM
Practicing my perpendicular parking ![]() ![]() ![]() ![]() Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
Time to bump an old thread!
I am about ready to stick my rebuilt and regeared 901 onto the LT1. I have a Renegade adapter and a KEP flywheel, PP, clutch disk and release bearing. My understanding is that bending the clutch fork or adding spacers on the pivot ball is required due to flywheel resurfacing. Well this flywheel is brand new, and I only have about 10mm of space instead of the required 20mm. It looks like I would need about 1/4" of spacers.. too much. So do I just bend the fork and git-r-done, or do I have the wrong release bearing? I measured the adapter thickness before I ordered all the other stuff from KEP, so it _should_ be right. |
jkeyzer clutch release fork problems Jul 30 2004, 12:29 AM
jkeyzer Keeping that in mind, I thought hmmmmmm maybe that... Jul 30 2004, 12:31 AM
jkeyzer In addition to this there were 2 thin washers unde... Jul 30 2004, 12:33 AM
jkeyzer I need to add MORE washers to get the 20mm (0.78in... Jul 30 2004, 12:36 AM
jkeyzer So my question is - what do I do?
Can I get by wi... Jul 30 2004, 12:39 AM
jkeyzer :bump: Jul 30 2004, 02:24 PM
SirAndy <... Jul 30 2004, 02:30 PM
bondo I have a stack of used flywheels, if you come to t... Jul 30 2004, 02:45 PM
jkeyzer Andy,
Yes, that is the ideal solution. But I wou... Jul 30 2004, 02:46 PM
bondo You can get by with 1 mm... but as the clutch wear... Jul 30 2004, 02:53 PM
bondo er, when I say 1 mm, I mean the free play of the f... Jul 30 2004, 02:55 PM
SirAndy <... Jul 30 2004, 03:15 PM
jkeyzer It wiggles a lot. At least 15-20 mm. That is the... Jul 30 2004, 03:18 PM
SirAndy bend here, towards the engine (away from the trann... Jul 30 2004, 03:18 PM
SirAndy <... Jul 30 2004, 03:20 PM
jkeyzer are you serious? Andy, you're scaring me.
An... Jul 30 2004, 03:26 PM
bondo Ahh, ok, I misunderstood the problem. Bend that su... Jul 30 2004, 03:30 PM
SirAndy <... Jul 30 2004, 03:31 PM
bondo <... Jul 30 2004, 03:33 PM
jkeyzer Ok. So that solves the problem of the fork hittin... Jul 30 2004, 03:37 PM
SirAndy <... Jul 30 2004, 03:40 PM
jkeyzer Andy -
I bent the fork just like you said and it ... Aug 12 2004, 11:33 PM
SirAndy <... Aug 13 2004, 12:30 PM
MarkV How much did you have to bend it? Do you have a ph... Aug 13 2004, 01:56 PM
jkeyzer Well, I would have a picture, but someone STOLE my... Aug 13 2004, 02:13 PM
914fan I am having a simular problem. My clutch is worn (... Mar 4 2006, 09:23 PM
bondo Mar 4 2006, 10:20 PM
bondo Bump! http://www.914world.c... Mar 5 2006, 04:59 PM
SirAndy Apr 9 2006, 02:56 PM
"7" Apr 9 2006, 03:02 PM
"7" nother - Apr 9 2006, 03:03 PM
SirAndy Apr 9 2006, 06:02 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th April 2026 - 10:09 AM |
