Boldylocks |
Member ![]() ![]() Group: Members Posts: 120 Joined: 10-September 03 From: San Diego -CA- Member No.: 1,135 ![]() |
First, I'm the owner of a 73 914 with a 1.7 liter engine that has bent/broken intake valves. I'm not a mechanic, but the cost to repair this part seems to be as much, if not more, than finding a running engine and putting it into the car.
With that said: Can I 'drop' any 914 engine into the car??? 1.8 -2.0?? Is the mechanic correct, will it cost me nearly the same amount to simply find (FAR FROM SIMPLE) a running engine and have it put in the car??? Can I 'drop' any of the larger engines into the car without any problems??? ___ next level questions_____ Anyone with any ideas of the causes for a 'big bore' engine to RUN HOT . there is no thermostat connected to the engine and after about an hour of running it starts heading into the red zone. -for direct contact: Rfranklin@price-entities.com -during the day (pacific time), Riccif@cts.com -at night. I would really really appreciate anyones help/response. I'm always greatful to this board and point eveyone I know in its direction. My current 914 was purchase after many hours of discussion on this board and it is a gem. The ENGINE was damaged due to mandatory driving on the face of the MOON in order to get to work for nearly 3 months (streets on my way to work -were pothole infested- caused serious damage to exhaust/engine -though again, according to what I have learned I simply have an 'intake valve -bent/broken' issue). |
tat2dphreak |
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region ![]() ![]() |
if the 1.7 just needs head work, the work isn't much at all... infact, see a post I made earlier today... some cat has 2.0L heads on theSAMBA.com
if the 2.0 is running hot after 1 hour, it could be an incorrect compression ratio... what size big bore is it? bigger than 96mm is usally bad... also look at pelican's 911 classifieds if you want a 6... there are several engines on there that were rebuilt recently... http://forums.pelicanparts.com/forumdispla...p?s=&forumid=17 if you are in Ca, depending on the year, you may have to stay fuel injected for smog reasons... I just learned that recently. |
Lo-Fi Version | Time is now: 3rd July 2025 - 11:54 AM |
