1975 1.8 L L-Jet, Questions... |
jim_hoyland |
Mar 6 2006, 10:00 PM
Get that VIN ? Group: Members Posts: 9,321 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Over the weekend, I read several threads on the L-jet hose connections; then went and looked at mine. Map a map so I could verify the connections. I have a couple of basis questions now:
1. The throttle body has two small hoses; one goes to each side of the distributer-retard and advance vacs. Question: Does it matter which goes to the advance and retard ? 2. AAR valve was tested and it closes when 12 volts is applied. Question: How far should it open ? Looked about 25% open to me; and a second one does the same. 3. The decel valve has 2 large hose connections and one small one. the small one hooks up in a Y to the Fuel pressure regulato, ant hen hookk to a second Y to the ERG and then to the plenum. Question: Is this correct ? 4. Are the boots , between the AFM and throttle body replaceable with any after market products? |
Lo-Fi Version | Time is now: 11th June 2024 - 08:30 AM |
