1800 stroker |
1800 stroker |
bd1308 |
Mar 14 2006, 08:27 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
is this possible? I mean I would think it wouldnt be IMPOSSIBLE, but i was just looking for a summer project....
Just thinking out loud, dont bash me for not thinking or researching anything. Just extending the britt feelers out there to see who knows what about stroker engines.... Assume this will be ran with aftermarket EFI (megasquirt). b edit: actually, assume this will be run with my weber DGEV carb (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) (someone get Joe Richard over here, he'll die) |
Mueller |
Mar 14 2006, 08:50 PM
think about it:
if you increase your crank stroke, what does it affect? with the stock rod and piston it would cause the piston to slam into the head, so, you can use a shorter rod or use a piston with a pin height closer to the top of the piston.... 2.0 cylinders will fit right into the 1.8 heads and for the 1.7 heads, you just open them up...the cost should be about $50 or so to mill 'em out..... the cheapest method to build a stroker out of your 1.7/1.8 would to convert it to a 2.0...... maybe I'm wrong, but if it was that easy, we'd see more people doing it....you should contact 914V6 or is that V6914?? he is into building odd ball combo's on the cheap.... |
Lo-Fi Version | Time is now: 16th June 2024 - 07:20 AM |
