> 914-6 conversion parts ID, will 911 column parts work on a 914
oemexp
post Mar 15 2006, 12:52 PM
I have an 84 carrera dodnor car I'm using for motor, guages, struts, brakes etc. Can I use the ignition switch, wiper/signal switches on the 914? I've heard the column frame (metal that holds the electronics) is different. if so, can I use the stuff on a 914-6 frame? can the 911 frame be modified to be the same?
Mark
dflesburg
post Mar 15 2006, 09:02 PM
Geez and I thought it was more trouble than it was worth just mounting and wiring in my -6 stuff into my 74 car...
It was a PIA but I can send you the wiring for the ignition if you would like, the wipers were easy, I am still finishing the turn signal switch wiring.
- Lo-Fi Version Time is now: 2nd April 2026 - 04:40 PM
