| oemexp |
Mar 15 2006, 12:52 PM
Member ![]() ![]() Group: Members Posts: 70 Joined: 5-June 05 From: Fremont, CA Member No.: 4,204 |
I have an 84 carrera dodnor car I'm using for motor, guages, struts, brakes etc. Can I use the ignition switch, wiper/signal switches on the 914? I've heard the column frame (metal that holds the electronics) is different. if so, can I use the stuff on a 914-6 frame? can the 911 frame be modified to be the same?
Mark |
| sechszylinder |
Mar 16 2006, 03:25 AM
Member ![]() ![]() Group: Members Posts: 271 Joined: 9-April 03 From: /earth/europe/germany/berlin Member No.: 545 Region Association: None
Hi Mark,
have a look at my conversion. The donor was as well a 84 carrera. I've welded the original mounting plate of a 914/4 column to the carrera column. You can use the ignition switch and all other electrical components, but you have to rewire them, cause the 914/4 connectors doesn't fit to the 911 parts. Benno Attached image(s)
oemexp 914-6 conversion parts ID Mar 15 2006, 12:52 PM
ClayPerrine Here's some information about my converted 91... Mar 15 2006, 01:28 PM
oemexp Thanks for that. I looked at the pictures but it ... Mar 15 2006, 08:57 PM
dflesburg Geez and I thought it was more trouble than it was... Mar 15 2006, 09:02 PM
ClayPerrine Mark,
The 911 column uses a completely different... Mar 15 2006, 10:14 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:57 PM |
