> Wiring for running, brake and turn signals, for flat towing, behind tow vehicle
DanT
post Mar 16 2006, 10:22 PM
Going back to the Dark Side!
Anyone done the clean set up of actually tapping into the existing wiring or harness to run turn signals, running lights, and brake lights?
Running these off the tow vehicles lighting circuits. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
I am sure it can be done, just want to know if anyone has gone here before.
If so how did you do it, what does your wiring diagram look like?
No I am not interested in aftermarket magnetic tow lights.
Thanks
Demick
post Mar 16 2006, 11:32 PM
Ernie made me do it!
Dan
I haven't done it, but I've thought about it. The first thing is to figure out what wires will be coming from the tow vehicle. If it is the standard old 4 wire connection, then it will be difficult because the running lights and blinkers are shared (but they of course are not shared on the 914). So the only way I would do this is if you have a 5 wire connection (ground, brake, left blinker, right blinker, and running lights).
You'll need to connect the ground to the body of the 914. Then you should be able to easily splice into the running lights and the right blinker at the right front corner of the car. Left blinker at the left front corner. Then you only need to run a single wire into the passenger compartment where you should be able to tap into the brake lights at the brake switch in the pedal cluster. That should do it.
Demick
Dan (Almaden Valley)   Wiring for running, brake and turn signals   Mar 16 2006, 10:22 PM
Demick   Dan I haven't done it, but I've thought a...   Mar 16 2006, 11:32 PM
trekkor     Mar 16 2006, 11:43 PM
Dan (Almaden Valley)   Demick, That is pretty much what I was thinking. ...   Mar 17 2006, 12:00 AM
Dan (Almaden Valley)   <...   Mar 17 2006, 12:05 AM
racergreg   Dan, I did this about 5 years ago and have been fl...   Mar 17 2006, 12:14 AM
Dan (Almaden Valley)   Racergreg, thanks for the info. could you give m...   Mar 17 2006, 12:21 AM
racergreg   Because it was easier, I tapped into the wires in ...   Mar 17 2006, 12:50 AM
Dan (Almaden Valley)   Thanks again for the info. I will check out my lo...   Mar 17 2006, 12:56 AM
Dan (Almaden Valley)   Got it all done. Thanks for the tips and the inf...   Mar 17 2006, 05:48 PM
- Lo-Fi Version Time is now: 8th July 2025 - 02:50 PM
