> What medium to use?, Soda, Sand, Walnut, Plastic, etc.
Poor-sche Lover
post Mar 18 2006, 07:38 PM
I have recently gained access to a high quality sandblaster, but I really don't know much about the process. I have a few questions.
1) Do I have to use sand for the blaster, or can I use something else in it? I've heard that you can't use soda because of the way it feeds into the system?
2) I want to use soda because it's less abrasive, but I read that soda will not remove the rust. I definitely need to remove the rust. Which type of medium is best for this?
3) Can you give me any general advantages/disadvantages of soda, sand, walnut, or plastic? Any others that I don't know about?
Any advice/suggestions/info you could provide would be helpful. Nobody around really does this, so farming it out isn't a viable option. It's either this or the long way, and I'd really like to blast if I can. Thanks for your help, guys.
Poor-sche Lover
post Mar 18 2006, 09:37 PM
Will the medium grit walnut shell do anything to potential rust?
Poor-sche Lover   What medium to use?   Mar 18 2006, 07:38 PM
d914   i'm going to get the car soda blasted...here i...   Mar 18 2006, 08:16 PM
Korijo   i like medium grit walnut shells. wont get in all...   Mar 18 2006, 09:26 PM
Poor-sche Lover   Will the medium grit walnut shell do anything to p...   Mar 18 2006, 09:37 PM
iamchappy   I've had trouble with the walnut clogging up m...   Mar 18 2006, 09:40 PM
Korijo     Mar 18 2006, 09:59 PM
Poor-sche Lover   So, you can use the walnut in a "regular" blaster?...   Mar 18 2006, 10:16 PM
Pistachio     Mar 19 2006, 06:02 AM
JPB   If your sandblaster is a preasurized type or just ...   Mar 19 2006, 07:33 AM
Poor-sche Lover   As I read more and more, I am thinking that the be...   Mar 19 2006, 12:10 PM
rhodyguy   gallons of air per hour and tank capacity of the c...   Mar 19 2006, 12:30 PM
Korijo
- Lo-Fi Version Time is now: 17th July 2025 - 03:37 AM
