> What medium to use?, Soda, Sand, Walnut, Plastic, etc.
Poor-sche Lover
post Mar 18 2006, 07:38 PM
I have recently gained access to a high quality sandblaster, but I really don't know much about the process. I have a few questions.
1) Do I have to use sand for the blaster, or can I use something else in it? I've heard that you can't use soda because of the way it feeds into the system?
2) I want to use soda because it's less abrasive, but I read that soda will not remove the rust. I definitely need to remove the rust. Which type of medium is best for this?
3) Can you give me any general advantages/disadvantages of soda, sand, walnut, or plastic? Any others that I don't know about?
Any advice/suggestions/info you could provide would be helpful. Nobody around really does this, so farming it out isn't a viable option. It's either this or the long way, and I'd really like to blast if I can. Thanks for your help, guys.
Poor-sche Lover
post Mar 19 2006, 12:10 PM
As I read more and more, I am thinking that the best way to go would be to soda blast the whole car, then go back and sand blast on the spots where I'm likely to find rust. Does anybody know how much soda it would take to do a whole car? Can I use the same blaster for both the soda and sand? Isn't a blaster just a huge air compressor with a hose on it? It shouldn't matter, then, should it? Thanks.
Alan
Poor-sche Lover   What medium to use?   Mar 18 2006, 07:38 PM
d914   i'm going to get the car soda blasted...here i...   Mar 18 2006, 08:16 PM
Korijo   i like medium grit walnut shells. wont get in all...   Mar 18 2006, 09:26 PM
Poor-sche Lover   Will the medium grit walnut shell do anything to p...   Mar 18 2006, 09:37 PM
iamchappy   I've had trouble with the walnut clogging up m...   Mar 18 2006, 09:40 PM
Korijo     Mar 18 2006, 09:59 PM
Poor-sche Lover   So, you can use the walnut in a "regular" blaster?...   Mar 18 2006, 10:16 PM
Pistachio     Mar 19 2006, 06:02 AM
JPB   If your sandblaster is a preasurized type or just ...   Mar 19 2006, 07:33 AM
rhodyguy   gallons of air per hour and tank capacity of the c...   Mar 19 2006, 12:30 PM
Korijo
- Lo-Fi Version Time is now: 17th July 2025 - 04:00 AM
