| DanT |
Mar 20 2006, 06:26 PM
Going back to the Dark Side! ![]() ![]() ![]() ![]() Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
Got my tow bar bracket a couple weeks ago from David Lee.
You can find the thread in the resources section about purchasing one. They are very sturdy and bolt right into the existing reinforced mounting area for the front of the A arms/torsion bars. A very nice piece of equipment right from one of our very own. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Doesn't take very long to install. The following are a few pics I took during intallation. The first pic is what you see when you first look under the front of your teener and begin the install. You will see the 2 normal 17mm bolts and inside the protector cup for the front of the torsion bar tube is an 8mm allen. Up inside the little slot on the front of the cup. Attached image(s)
| DanT |
Mar 20 2006, 08:36 PM
LE spoiler is a non-issue. Absolutely no interference.
Spoiler remained in it's usual position during intall. Spoiler also has no interference during use of the Empi tow bar. David also makes a similar bar with correct attachments for a "Draw tite" tow bar. Mine is for a superbeetle tow bar. Looks very similar. This was the easiest and simplest method I have seen for flat towing a 914. David and I emailed back and forth with ideas and designs before this one was settled on. I originally was planing on fabbing up my own bracket using a set of David's tow eye brackets...which these final product tow bar brackets are based on. this is a great product and comes with everything you need to install. Bracket, new hardware, and spacer for front mounting bolt. When finished it does not protrude beyond the spoiler. Actually is behind the vertical plane of the spoiler by about 2-3 inches. It also does not hang down in harms way. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Dan (Almaden Valley) Tow Bar Bracket Mar 20 2006, 06:26 PM
blitZ Don't leave us waiting in anticipation like th... Mar 20 2006, 06:38 PM
Dan (Almaden Valley) Sorry about the delay couldn't get back on the... Mar 20 2006, 06:58 PM
Dan (Almaden Valley) next shot shows the bar in place and hardware in f... Mar 20 2006, 06:59 PM
Dan (Almaden Valley) and another
As you can see from this photo, I mou... Mar 20 2006, 07:01 PM
Dan (Almaden Valley) another Mar 20 2006, 07:02 PM
Dan (Almaden Valley) last one Mar 20 2006, 07:03 PM
STL914 Dan,
It looks like you were able to install the b... Mar 20 2006, 08:00 PM
BigDBass Is there a limit to the range for which flat towin... Mar 20 2006, 09:22 PM
Dan (Almaden Valley) I have several friends that have been flat towing ... Mar 20 2006, 09:26 PM
Dan (Almaden Valley) a couple of full perspective of install Mar 20 2006, 10:15 PM
If you look closely you can see my ve... Mar 20 2006, 10:16 PM
trekkor Looks like everything is coming towgether for you ... Mar 20 2006, 11:28 PM
Dan (Almaden Valley) yes, the bracket is very strong. You could probab... Mar 20 2006, 11:37 PM
STL914 Dan,
Any chance of posting a picture of your car ... Mar 21 2006, 06:22 AM
blitZ Just an FYI.
I attempted to purchase the Draw Tit... Mar 21 2006, 07:17 AM
Paul Illick That tow bar attachment appears strong enough to b... Mar 21 2006, 07:42 AM
STL914 Mar 21 2006, 12:01 PM
Dan (Almaden Valley) Mar 21 2006, 03:37 PM
racergreg Glad to hear that the wiring worked out for you... Mar 21 2006, 05:02 PM
dlee1967 Hey Dan or Greg, how about some details on the par... Mar 21 2006, 07:47 PM
Gint ... Mar 21 2006, 08:12 PM
Dan (Almaden Valley) I used a roadmaster universal wiring kit. It come... Mar 21 2006, 08:31 PM
dlee1967 Nice.....thanks Dan! Mar 21 2006, 10:35 PM
Gint ... Mar 21 2006, 10:49 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th March 2026 - 07:08 PM |
