> Sticking Throttle Cable, the saga continues ...
vesnyder
post Mar 21 2006, 07:01 AM
I want to thank everyone who has assisted so far in debugging my car in making it road worthy, despite my blunders. The latest is a sticking throttle or over revving engine? I've replaced the throttle and clutch cable and think I've made sure they are clear of each other - several times - but yesterday on a road test the motor surged as I was exiting a freeway to the point of engine damage (I think I escaped anything permanant?). I am not 100% convinced that the cable/pedal is sticking - any chnace that the throttle body is wacked? How about adding a stronger spring? I lubed the throttle body but I am not confident I've found the source of the problem and I've got too much work into this to blow the engine before I get a Summer of driving out of it!!
Dr Evil
post Mar 21 2006, 09:52 AM
Send me your transmission!
Mine stuck on the lower part, but that does not rule out the upper air cleaner housing (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) If you move the throttle by hand you will likely accomodate for this, and/or your air filter housing will be removed. If you have someone actuate the pedal inside while you watch the throttle you may find the culprit.
vesnyder   Sticking Throttle Cable   Mar 21 2006, 07:01 AM
JJ914   Hey, I had a similar problem with my car, but my ...   Mar 21 2006, 07:46 AM
olav   I had a throttle cable that got bound up. I replac...   Mar 21 2006, 08:25 AM
vesnyder   I used the Terry cable which says that you should ...   Mar 21 2006, 08:41 AM
Dr Evil   Mine stuck once like that. It turned out to be the...   Mar 21 2006, 09:09 AM
Dr Evil   I, too, added more spring. You can get them at you...   Mar 21 2006, 09:12 AM
vesnyder   Dr Evil - I think you may be on to something? Are...   Mar 21 2006, 09:47 AM
Dr Evil   Mine stuck on the lower part, but that does not ru...   Mar 21 2006, 09:52 AM
goose2   Throttle stuck wide open on my six once...I got it...   Mar 21 2006, 09:56 AM
Joe Sharp   I've had the throttel cable wraped around the ...   Mar 21 2006, 06:13 PM
Rand     Mar 21 2006, 06:25 PM
- Lo-Fi Version Time is now: 9th October 2026 - 11:43 PM
