| pib |
Mar 21 2006, 01:19 PM
Re Member ![]() ![]() Group: Members Posts: 116 Joined: 5-February 06 From: Monterey, CA Member No.: 5,530 |
Saturday night I thought I snapped a clutch cable. I was pushing the clutch in, there was a loudish noise, and the pedals been on the floor ever since.
I ordered a cable yesterday, and it arrived this morning. I put the car on jack stands (for the first time), and after staring at the damn rust for a while (IMG:http://www.914world.com/bbs2/html/emoticons/barf.gif) I got to looking at the clutch cable. So here's the weird thing. The cable appears to be intact. If I pull on the end at the tranny, the pedal actually goes back to it's normal postion. So, all you experienced people out here, what should I look at next? What else could cause a cable to seemingly grow a couple inches in an instant? I looked in the tunnel, as best I could, and the tubes all appear to be attached. Also, is it 'normal' for the clutch cable and accel cabel to be this close to each other? They're almost touching. Attached image(s)
pib And while I'm posting pictures...and at the ri... Mar 21 2006, 01:22 PM
914-8 post a closeup picture from underneath the car, wh... Mar 21 2006, 01:24 PM
Dr Evil The box is an EGR somthing or other. Its for the e... Mar 21 2006, 01:27 PM
Andyrew If the cable is intact.
and you heard a snap.
th... Mar 21 2006, 01:29 PM
JOHNMAN I bet your clutch tube is loose now and needs to b... Mar 21 2006, 01:30 PM
Andyrew That wouldnt explain why his pedal is to the floor... Mar 21 2006, 01:33 PM
pib Mar 21 2006, 01:39 PM
pib <... Mar 21 2006, 01:41 PM
Eddie Williams Yeah, judging by the rust, I'm going to go out... Mar 21 2006, 01:41 PM
914-8 Yep, as I suspected, the picture tells the tale.
... Mar 21 2006, 01:49 PM
pib All of this started two days after replacing the s... Mar 21 2006, 01:51 PM
jd66921 Be careful welding the clutch tube. The gas lines ... Mar 21 2006, 01:57 PM
pib Thanks to all of you for your help! I'm p... Mar 21 2006, 02:00 PM
fiid Theres a classic thread about fixing the clutch tu... Mar 21 2006, 04:31 PM![]() ![]() |
Lo-Fi Version | Time is now: 25th September 2026 - 09:31 AM |
