7.5mm Fuel Injection hose, which? |
yarin |
Mar 13 2006, 10:17 AM
'14-X'in FOOL Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
I found this site which suggests purchasing this hose from a VW dealership.
http://www.type2.com/library/fuel/fuel-lines.html I called my local VW dealership and they can order it. 5 meters of hose for $63. That comes down to $3.80/ft. The part number is N 020 281 1. The guy doesn't have any details about it though, can anyone confirm this is 7.5mm ID fuel injection hose? I also found 7.5mm hose at here: http://www.international-auto.com/pdf_files/IAP12.pdf for $2.90/foot. I called and asked what brand, they said the only marking on the hose is NBR/CR. Acceptable? Cap'n |
watsonrx13 |
Mar 22 2006, 06:17 AM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
Cap'n, I'm in for a set. I've just removed my fuel tank and will be sending it out for inspection and cleaning. I would like to replace ALL rubber fuel lines in the car (not replacing the plastic lines in the center tunnel). I'm assuming that the lines that you're providing in this post is for the engine compartment only.
Can you also get the larger diameter lines that I'll need? What is the dimensions of the larger hose, dia x wall thickness x length? To recap, I would like all of the rubber fuel lines from the fuel tank to the injectors... -- Rob |
Lo-Fi Version | Time is now: 28th May 2024 - 12:16 PM |
