Break Away Torque, HOw to calculate |
Brett W |
Mar 26 2006, 11:44 PM
Advanced Member Group: Members Posts: 2,856 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None |
We all know that the torque needed to loosen a fastener is usually higher than the torque at which the fastner is tightened. Is there a way to calculate this number.
I just got a new 3/8 Impact wrench and was doing some test with it. We torqued a 1in course thread bolt to 250 ft-lbs. Then used this impact to break it loose. It did it with no problems at 175 psi. Couldn't touch it at 90psi. ANy body know how to calculate that torque? |
McMark |
Mar 27 2006, 01:46 AM
You're right I guess I didn't finish my thought. Once he determines the tightening torque that corresponds to a 300 ft/lbs break-free torque then he has determined the setup he needs in order to conduct his test. Everything I typed before is just for setting up the test, it's not actually doing the test.
Lo-Fi Version | Time is now: 7th June 2024 - 02:37 PM |
