Break Away Torque, HOw to calculate |
Brett W |
Mar 26 2006, 11:44 PM
Advanced Member Group: Members Posts: 2,856 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None |
We all know that the torque needed to loosen a fastener is usually higher than the torque at which the fastner is tightened. Is there a way to calculate this number.
I just got a new 3/8 Impact wrench and was doing some test with it. We torqued a 1in course thread bolt to 250 ft-lbs. Then used this impact to break it loose. It did it with no problems at 175 psi. Couldn't touch it at 90psi. ANy body know how to calculate that torque? |
Joe Ricard |
Mar 27 2006, 06:18 AM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Hmm, SO who really gives a rat's ass how much torque it takes to get a bolt off. As long as it comes off. However you guys were tippy toeing around the real important part. Impact wrenches do not do a good job of obtaining exact torque.
Torque wrench for my lugs ONLY. engine assembly is the same. My preference is the deflecting beam. but If I had enough money the click Snap on would be ok. SOmething nobody talks much about is "running Torque" Which is the torque it takes to trun a Nylock or other self locking nut before it reaches the contact surface. |
Lo-Fi Version | Time is now: 7th June 2024 - 02:27 PM |
