JPB |
The Crimson Rocket smiles in your general direction. ![]() ![]() ![]() ![]() Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 ![]() |
Aircooledclassics has an electric horizontal fan set up for 914 engines. My question is has anyone ever seen one in use or used one? It looks like a good idea but wonder if it would be good for street applications since they imply for "racing". 1200 cfms is not much wind compared to stronger fans on the market that can even push 3500+CFMs. If it does save HP from the power plant, then its worth it and it will give the engine a stead air stream compared to the belt/fan deal which will only supply higher CFMs at higher REVs. (IMG:http://www.914world.com/bbs2/html/emoticons/popcorn[1].gif)
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,248 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
looks like the only way to find out is for you to buy and install one chris. strap the car to a dyno, give it a run or 2, switch back to stock, 2 more runs, and report with your readings.
k |
Lo-Fi Version | Time is now: 3rd July 2025 - 06:34 AM |
