Hyfire VIa Wiring, Help ! |
MarkV |
Mar 27 2006, 12:30 PM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
I installed a Hyfire VIa yesterday. The car starts up and idles fine. Took it for a spin and it shut off after about a block. It will restart but then dies again. Made it home after restarting it 3 or 4 times. Can't restart it without using the starter, won't restart with momentum & the clutch.
I am using a Mallory dual point dizzy & a Pertronix 1.6 ohm Blaster coil w/ no ballast. It is wired as follows: I have the large red wire going to the battery & the large black wire to chassis ground. The small black wire to the - side of the coil & the orange wire to the + side of the coil. The white wire goes to the points lug on the dizzy. The small red key on wire is going to the old + coil wire from the harness. Oh & my tach doesn't work. Hooked the tach trigger wire up to yellow wire from the box and the tach does nothing. The diagnostic LED glow solid while it is running & shuts off when it dies. |
yeahmag |
Mar 27 2006, 01:42 PM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Does the coil get hot? Are you positive you have a good ground and positive connection? The tach problem may be that you need the tach driver box. Some need it... Some don't.
-Aarpm |
Lo-Fi Version | Time is now: 1st June 2024 - 12:23 PM |
